Page 72 of 75
FirstFirst ... 22 62 70 71 72 73 74 ... LastLast
Results 2,131 to 2,160 of 2222
    Aug 2013
    Central Germany
    x265 2.7+12-98e48e8dd6ab
       --refine-intra <0..4>         Enable intra refinement for encode that uses analysis-load.
                                        - 4 : Re-evaluate all intra blocks, does not reuse data from save encode.
       --[no-]dynamic-refine         Dynamically changes refine-inter level for each CU. Default disabled
       --[no-]idr-recovery-sei      Emit recovery point infor SEI at each IDR frame
  2. Marsia Mariner
    Guest
    deleted
  3. Marsia Mariner
    Guest
    x265.exe 2.7+20-3440a56acc78
    fix bug in SEI::write clean up
    Aug 2013
    Central Germany
    x265 2.7+20-3440a56acc78
    Aug 2013
    Central Germany
    x265 2.7+22-946f82dbf4e8
    dynamic-refine tunings
    Aug 2013
    Central Germany
    x265 2.7+332-593e63cda903 (Win64)
    Support for AVX-512 assembly optimized kernels; remember: enable it manually by adding --asm avx512 to the CLI — and don't fry your CPU...
    Only x86-64 (Win64) version available, skipping it in x86 (Win32) mode for NASM is necessary not to break compilation completely.
  7. Marsia Mariner
    Guest
    ^ Thanks for the newest build.
    This time I have nothing important to say... yeah, the recent AVX-512 stuff has made x265 somewhat fatter
    Aug 2013
    Central Germany
    x265 2.7+337-54ff74d2b635
    • Merge with default; prep for v3.0
    • Support for HLG-graded content and pic_struct
    • Fix conditions for single-sei NAL
    • Fix 32 bit build error (means: AVX-512 support is only included in x86-64 architecture target)
    (VMAF support to report per frame and aggregate VMAF score — unfortunately not yet? available for Windows builds)
    New CLI parameters:
       --atc-sei <integer>           Emit the alternative transfer characteristics SEI message where the integer is the preferred transfer characteristics. Default disabled
       --pic-struct <integer>        Set the picture structure and emits it in the picture timing SEI message. Values in the range 0..12. See D.3.3 of the HEVC spec. for a detailed explanation.
    Aug 2013
    Central Germany
    x265 2.7+340-aa9102400f24
    remove unused asmname from x265_param (may fix some crashes on Xeons); added a newline in the help
    (fixed VMAF warning not applicable under Windows)
    Aug 2013
    Central Germany
    x265 2.7+346-69aafa6d70ad (stable merge)
    AVX-512 cleanups and a few nits (getting a RC soon?)
    Aug 2013
    Central Germany
    x265 2.7+348-0968a46d6ba4
    fixes a build error on Mac and a calculation bug in scalefactor 0
    Aug 2013
    Central Germany
    x265 2.8+1-478bfe2b7673 (stable release, GCC 7.3.0, Win32+Win64)
    last few fixes in analysis mode
  13. Marsia Mariner
    Guest
    x265.exe 2.8+10-a7bd0622ece5
    off-topic: still compiling with gcc 7.3.0.... because I don't know whether the "upgrade" to GCC 8.1.0 would be worth the hassle
    Aug 2013
    Central Germany
    x265 2.8+10-a7bd0622ece5 (merge with stable)
    several bug fixes (build errors, dyn.ref., scaled enc.)
    I won't hurry to GCC 8.x either. When MSYS2 updates, it gets updated.
  15. Marsia Mariner
    Guest
    x265.exe 2.8+12-9cde2c278464
    doc: Add recently added SEI and pic-struct to cli doc
    fix signed/unsigned mismatch warning in windows
    ~"merge with stable"~
    This time I did not forget to enable "VMAF support" in the build script.
    Not sure of how useful that will be though.
    Aug 2013
    Central Germany
    VMAF will be ignored in Windows builds. And it will not work for multilib builds, not even on Linux.
  17. Marsia Mariner
    Guest
    Thanks for the info
    Have they explained the reason why?
    Also: are you sure they didn't mean *MSVC* when they said "Windows"?
    (yes, the x265 devs can be that stupid)
  18. Member
    Aug 2013
    Central Germany
    I don't remember any reply yet on the mailing list. I already suspected that an MSYS2/MinGW environment might be able to handle that if there is not a Windows specific reason to fail.
    Aug 2013
    Central Germany
    x265 2.8+19-bcdc610cf5f0
    Support scale factor with analysis-reuse-level 1-6; fix build issue when using icc; add support for chunked encoding*; use the data structure of analysis-save/load for multi-pass-opt-analysis/multi-pass-opt-distortion; add vbv-end tolerance check
       --chunk-start <integer>       First frame of the chunk. Default 0 (disabled)
       --chunk-end <integer>         Last frame of the chunk. Default 0 (disabled)
    * this seems to allow the output of parts of a GOP, with bitrate control beyond this GOP where required, possibly to support "smart rendering"
    Aug 2013
    Central Germany
    x265 2.8+24-289b8a3730ae
       --nalu-file <filename>        Text file containing SEI messages in the following format : <POC><space><PREFIX><space><NAL UNIT TYPE>/<SEI TYPE><space><SEI Payload>
    was --usersei-file a "moment" ago...
    Aug 2013
    Central Germany
    x265 2.8+40-0106f9f2f867
    several new AVX(2) assembler routines
  22. Member
    Aug 2013
    Central Germany
    x265 2.8+47-e2759ae31c36
    several fixes related to HDR10+ LLC JSON and dependencies between effects of options
  23. Member
    Aug 2013
    Central Germany
    x265 2.8+57-eea92165b035
    Enhance VBV lookahead of RADL pictures (and a few more small building and API fixes)
  24. Member
    Aug 2013
    Central Germany
    MSYS2 recently updated MinGW64 with GCC 8.2.0; due to some internal compiler errors, MinGW32 will stay with GCC 7.3.0, though, until these issues are solved.
    x265 2.8+58-d17bc7714ed2 (Win32-GCC730 & Win64-GCC820)
  25. Marsia Mariner
    Guest
    x265.exe 2.8+66-88ee12651e30
  26. Marsia Mariner
    Guest
    x265.exe 2.8+68-fa57fa584898
    µChangeLog
    --- use one 32bit operation instead of two 16bit in MV union
    --- api: fix memory allocation of distortionData
    sse_t type depends of x265 default bit-depth
    if 8bit x265 try to allocate distortionData for 10bit encoding
    (possible in multilib build) we need double memory size for
    sse_t type tables (uint32_t -> uint64_t)
  27. Member
    Sep 2018
    France
    We were having some trouble with building libx265 with MinGW as the local version we had a on a dev machine was crashing, and the mingw server to upgrade to the latest version wasn't responding late last week. That is why there has been no updates here Notepad++ Malwarebytes FileZilla
    As a quick check, can you try to replace the #ifdef _WIN32 in x265-extras.h with #ifdef X265_API_IMPORTS to check if that fixes the problem? I recall running into a similar problem where MinGW behaves differently from other windows SDKs and therefore had to make a tweak like this in x265.h; the identical change isn't made in x265-extras.h.
  28. Marsia Mariner
    Guest
    Originally Posted by bimaloy30 View Post
    We were having some trouble with building libx265 with MinGW as the local version we had a on a dev machine was crashing, and the mingw server to upgrade to the latest version wasn't responding late last week. That is why there has been no updates here.
    The text above was actually written by an actual x265 developer @ https://bitbucket.org/multicoreware/x265/issues/360/v25-does-not-work-in-ffmpeg-24x
    So, my question is: ¿are you a spämmer?
  29. Member
    Aug 2013
    Central Germany
    x265 2.9+1-169e76b6bbcc (MSYS2; MinGW32: GCC 7.3.0 / MinGW64: GCC 8.2.0)
    surprise
  30. Member
    Aug 2013
    Central Germany
    x265 2.9+4-471726d3a046
    fixes: rowStat computation in const-vbv; memory reset size in dynamic-refine; linking issue on non x86 platform
